RS Logix 500 adding and averaging integer values
banditsrun
Mar 2008
Queensland
Hi there,
I have an expression N24:[N24:0], which places a value in data file N24, these values are indexed with reference to N24:0 according to the word and stored. How then would I create an average of these values.
If you can help, thanks in advance.
Dan
This post has two examples, The circular queue example has the advantage that you don't have to loop and you don't re-sum the entire range of values but keep a running sum and don't move large amounts of memory around - saves processor time.
Do a forum search on AVERAGE, you'll find tons of threads on the topic and lots of examples.
Dear Friends I want to understand the correct way for adding a rung in between a ladder program in RS Logix 500 as when I insert a rung, the...
19
7,636
How can I keep adding a value from one register to another and retain the added number so It keeps incrementing? Example. I want to add the...
2,882
I recently did a program conversion from logix 500 to studio 5000 and when machine runs it depends on two ton instructions to keep the machine in...
17
445
269
Hi Everyone, I am not proficient in RSLogix 500 so I have a question regarding the evaluation of N7:0 data as an input. So as I understand in...
108
