NTsx (nt3) Omron
Jason:
I have done several Omron HMIs, but I am not familiar with the NT3. Nor did I have any luck on Google. Do you have a more complete Model Number? I assume you are using NTST the NT Series Support Tool to program it?
Stu.....
I haven't worked on one of those, and I don't have the NTsx Software.
The Link to the manual posted by Bluebyu does have a section on setting up alarms, so start there.
Hopefully, someone with experience with them will show up.
Thanks all
I've got it! all very easy i just had to set the alarms as a HR/IR word and the alarms are then the the coil addresses EG :- 10.00 alarm 0 , 10.01 alarm 1 and so on. I was over complicating as usual !!!
Does anyone know how to remove any communication and programming info from a processor (TSX micro 3721 in particular). I need it to be blank like...
1,895
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
78
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
71
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
211
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
86
