shrirampendse
Hello,
I am trying to connect Rish Energy meter on Modbus RTU 9600 , 8 , N ,2 to M340 PLC or Delta PLC. PLC can read the data but it cannot be utilised in logic as every incoming data is four bytes (two consecutive registers e.g. 40071 and 40072 etc) in SWAPPED FLOATING POINT format. How do I convert these two registers to real value in PLC?
As a temporary measure I hooked EM to VijeoCitct SCADA using its byte swapping function. But that is only quick fix, Energymeter must connect to PLC only. Rish EnergyMeter support help is of no use as they know only this format and cannot give data on any other format.
Any solutions? Thanks.
