Allen Bradley 1784-PCMK USB Adapter
B_Leonhardt
Dec 2009
Nuremberg
Hello!
We use a lot of different PLC brands (e.g. Allen Bradley, Siemens, Mitsubishi, Keyence) in our products. For that reason, we decided to setup virtual machines under VMware to avoid conflicting drivers.
The problem is now that VMware (Host System and Guest System is Win XP) obviously does not support PCMCIA which we would need to connect to the A&B PLCs via our 1784-PCMK/A and -B Cards.
I already know that there's a USB to DH+ cable available from Rockwell but we can't afford buying new cables for 6 Notebooks at the moment.
Has anybody found a working solution with a USB to PCMCIA Adapter? I found some older posts regarding similar questions but none really answers it.
Thank you in advance!
I do not know of any USB/PCMCIA adapter that will work properly with 1784-PCMK/PCC/PCD cards.
Users have reported about 50% success with the Duel Systems adapter and ordinary Windows XP, but none of those users were also trying to connect to a virtual machine.
One workaround for VM's is to run RSLinx Gateway on the host operating system, and connect from the VM's to RSLinx Gateway over TCP/IP. That software is not inexpensive, but it will do what you describe and if you are a toolkit owner you already have it.
Thank you Ken.
I asked my colleagues in the U.S. and they are going to look if we already have a license for RSLinx Gateway but as they never heard of it I think we don't.
Do you know if there's another workaround possibility?
I have PanelView Plus 600 with the card slot that supports 1784-SDx and 1784-SDHCx SD cards. What're any compatible analogs?
2,311
hey guys. having some problems with my driver to connect to the SLC 5/04. I can configure it in rs linx, but when I go into rs500 to download the...
1,420
Hi, We have six 1783-NATR. Two of them can be accessed by the vendor is outside of out plant network via vpn. The other four cannot be...
1,920
HELP!!! I have an Allen Bradley 1784-T30G terminal. The program got dropped. I have the binary program but don't have a user manual to figure out...
1,308
Does anyone know of a Generic brand that works as well,the price on these are out of my price range thanks in advance for any info ..Mer
3,909
