Slc 5/04
studentplc1
Feb 2010
Canada
29
I have a SLC 5/04 programmed to run a process. I want to use a light beacon to signal any fault that occurs. How can I find out the voltage the output card on the PLC provides so I can order to correct beacon.
Thanks for your help!
and if the module you're using is a TRIAC type, make sure that the beacon presents enough of an electrical "load" - or it will stay ON even when the PLC turns the output OFF ... (most neon and some types of LED beacons will NOT provide enough of a load) ... search for TRIAC and "leakage current" on this forum and you should find out everything that you need to know about that piece of the puzzle ... note that with an SLC-5/04, the word "TRIAC" will usually appear right under the LEDs on the front of these types of modules ...
and welcome to the forum ...
Hello All! I am writing today because I cannot figure this out for the life of me. Another site I am affiliated with keeps having their slc 5/03s...
315
I’m attempting to send a temperature from a SLC-5/02 to an EZiMarquee display. The vendor said to use a MSG instruction to send the data to the...
110
Hello all. I have a few SLCs in my plant and of late we've seen a weird issue: The system will be running normally and then randomly the outputs...
122
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
130
I have a redundant ControlLogix being set up. This program reads a value from a remote site which happens to be SLC PLC. Rockwell mentions SLC...
160
