kallileo
I have a water tank and I use two water pumps that to pump the water out of the tank. When the water in the tank reaches the float sensor Pump A starts working. Until now the program is pretty easy even for a beginner like myself.
The problem is that the next time the water reaches the waterlevel sensor the pump that will start working should be Pump B. So I have to find a way to start the pump that wasn't working on the previous cycle for the next cycle.
Any tip on how to program it will be appreciated....
BTW I use Twido PLC...
