Rockwell Factory Talk Licenses
fran007
Mar 2009
Santo Domingo
Hello,
I'm developing and appliacation, where I going to use an Advantach HMI (Industrial Computer) and a Remote Computer (Desktop) running at the same time with the same access level, with maximum 75 Display.
Could you please inform, what licences of Rockwell Factory Talk Software do I need to buy?
Thanks.
AFAIK there are a few things that can be done in SE but not ME but not much. ME is primarily for PV Plus and a PV Plus Has a ME runtime already on it from factory it is embedded.
SE station is good if you plan on starting with one panel and plan to expand it to many. Going from SE station to distributed just means a couple license changes. Making one or more machines a server and many machines a client. You can convert from ME to SE but it is not without challenges. Some things don't convert and others fight you all the way.
If the application has any chance of ever becoming distributed and because you are starting with 2 computers i would choose SE if it were me. Just depends on where you plan to go with it. I am not sure about the differences in cost but you can get list prices from the ab website.
We have a FactoryTalk HMI running on an industrial PC. Which software do you need to edit and add screens to this ? I'm confused with Factory Talk...
3,836
In Rockwell Software, Factory Talk View ME, is there a way to purge the tags that are not in use anywhere within the screens of program? As far...
3,278
Hi I have just installed the Rockwell Faceplate for the 1769-L3x Controllers. Its working well however the memory is not displaying properly. I...
3,043
Has anyone here successfully used the View SE software under windows 7? I have gotten Linx Pro, Logix 5 and Logix 500 to work, but I cant get the...
13,200
Hello! I am using an AB Versa View 1200p with Factory talk View Machine Edition, version 5.0. I am having trouble printing out the alarm...
4,174
