Motor Current Monitor - 3 phases/1 input
bluenoser337
Apr 2003
Nova Scotia
391
Is anyone aware of a device that will measure the amps on 3 motor phases and provide an "average" value on a 4-20mA signal. I have a number of motors to monitor, and I could put a CT on every phase of each motor, but I don't have enough analog PLC inputs. Looking for a device that measures all phases, but only needs a single A/I. A nice addition would be if it also measured imblanace, phase voltages, etc and gave a digital signal for that (good/not good). Not looking for something with serial comms...simply an I/O connected device. Thanks!
Try your local electrical contractor for a 3 phase monitoring system. They come in various flavors and models.
about $300 each, but that was several years ago. If they don't know what your asking for, explain to them in detail what you want.
regards,
james
I'm looking for a way to monitor motor current on a grinder (600 VAC 3Ph., 50 Hp) and provide an alarm and/or automatic shutdown on overload. It...
5,650
HI i have a delta VFD M-series in the manual, in order to enter the motor rated current you set the parameter P,52 =the motor rated current my...
718
Hey guys. So I have a 50 HP 460/600V motor on a PF525. I've verified the motor is wired correctly. The service factor is 1.15 and the pf is 0.8...
24
1,972
Hi all, I am currently working on a software in Automation Studio that is supposed to detect when effort is inputted by a user. This is done via...
609
Hello all, I have some motors and I wish to read their current. Is there a device or module that can measure these and convert them to a standard...
4,034
