can someone convert this rss file to pdf?
Yes it is RSLogix500 file format. You can attach it to a post here if that's allowed by your company/customer. I think that is what Stu expected...that you'd simply attach it to a post (zip it first).
After extracting the file and changing the extension to rss, my software (RSLogix 500 version 8.10) will not open it. The file is created with a newer version or corrupted.
I've got the message "File is corrupted or user doesn't have access rights". This might mean the file is protected.
Kind regards,
Kind regards,
Yes, I bet you are right. I saw file is corrupt, and didn't pay close enough attention to what followed. It could also mean that it was created with the A.I. (Antique Interface:) ) or A.P.S. software...
well for some reason my computer has it associated as an outlook file and trys to open it as at text file when i double click on it. there is alot of jiberish in the file when it opens, but i can read this
Document=RSLogix_500_Project/&H00000000
Name="VBALogixProject"
HelpContextID="0"
VersionCompatible32="393222000"
CMG="EEEC3125F1FDDB01DB01DB01DB01"
DPB="DCDE03531F4020402040"
GC="CAC81549024A024AFD"
which would indicate it is indeed a rss file correct?
Hi, I only have the RSLogix Micro starter edition and cannot save as .SLC for the micrologix to micro800 conversion tool on CCW. I would be very...
3,727
Hello I have an .RSS file that I need converted to a text readable file.....txt or PDF perhaps? Can someone help with this? Thanks dk
2,389
Hello, Can someone please convert a .RSS program file to a PDF? See attached. It's from a MicroLogix 1200 system. Thank you! Michael
3,899
I recently started getting "corrupted or low disk space" errors on all my backup panelbuilder32 files seemingly out of no where (been running ver...
1,607
Can someone please convert this file to PDF from RSS thanks,
2,205
