S7 communication between two 315 cpu in plcsim
Plc_User
Dec 2005
Belgium
317
Is it possible to test S7-communication (BSEND BRECEIVE) between two S7 315PN cpu's or is it only possible with 400 PLC's. In my tests it worked for 400 plc's but not for 300 plc's. Am I doing something wrong or is it just the way it is?
I have done it with 317-pn/dp and et200s IM-151-7 CPU ie on profibus so i think this should work with 2 same cpu's
Hi Folks, I want to set up communication between: An 1513-1 PN (typ.: 513-1AL01-OAB0) , which is programmed in TIA V14; An 315-2 DP (typ...
2,441
I want to realize the communication S7 and pc by cable profibus or mpi I want to know the steps to that allows me to do it
1,274
Several months back we installed a Red Lion G315 HMI to communicate with a AB SLC 5/03 attached to the ethernet network via an AB ENI module...
4,492
We recently received a Red Lion G315 to be used to interface between an AB SLC 5/05 and several Micrologix 1400's via ethernet. This is my first...
10,008
Hey I have a question: how to communicate two PLC(315-2 DP) using Profibus. I manage to communicate them using HWConfig I/O but I know that...
16,937
