Node Id (1) not found error in RSview32 when creating a tag
ElVale
Jun 2010
Cartagena
23
I'm trying to create an analog tag to read a signal in Rsview32 from an analog input module but after configuring it and giving it the PLC address I click accept and get a dialog box error saying "Node Id (1) not found"
Can somebody help me with this? I beg you please, this is urgent.
What PLC are you communicating with? How about some screen shots of your Tag and the Error?
Stu.....
I'm using a controllogix. I've never seen this error before, I don't know what to do.
The tag I'm trying to create is DEN. The project is running in the back at full screen, (btw how do I bring the menu bar? I can't find it)
I am not sure what you mean by a DEN Tag.
If you mean the Project Dialog Box, try CTRL+ALT+P twice.
Stu....
This is can indicate a corrupt database and can be recovered by deleting the projects cache files. To do this:
1. Close the project.
2. Start Windows Explorer.
3. Delete the following in the project folder:
...\projectname\CACHE
...\projectname\TAG\projectname.CAC
4. Open project in RSView.
Hi, I have a PV550 DH+ and a SLC 5/04. I just changed the 5/04 last sunday by another one and since the PV does not communicate with the SLC...
2,676
Hello, I have a very important problem with the browsing network of my 1770 KFD. After reset the system by remove and plugg the keyspan usb to...
4,271
Dear all, I am beginer in ifix hmi programming. I have 2 ifix 6.0 pc with license FiX and client.. Can some one tell me how to configure sample...
180
Looking to tery and send some tags from wincc to node red dont have a wincc connectivity license so can use opc. Any suggestions ?
80
Hello All, getting my feet wet currently with Node-red, curious if anyone has experience with the SMB share add-in(or whatever the terminology...
316
