MicorLogix to SLC 5/05 communications configuration
rock2005
Jan 2009
Edmonton, Alberta
Hello all I am looking for some assistance in connecting a Micrologix 1200 (1762-L40AWA) to a SLC5/05 (1747-L551C) via a 1761-NET-AIC module.
The AIC will be connected to the Micrologix via the PORT 2 connector and the SLC5/05 will be connected to the AIC at PORT 1 and to the DB9 port on the SLC5/05.
All I need to do is get the the digitals from the Micro to the SLC the SLC will have all of the logic/control
Any help would be appreciated, never done this before so I'm a newb
This may be a stupid question, but I have several Compactlogix controllers that are using consumed / produced tags to transfer data between them...
3,308
I have a micrologix 1000 that I would like to connect with a panelview for graphics. What do I need for this connect as far as cables and...
3,822
after going online with a micrologix 1200 It will no longer communicate with the panelview plus 700. I powered it down went online and backed up...
3,240
We install a lot of stand by generators at residential sites. I have started using micrologix 1000 controlers for load shed of the air...
3,042
Hello I have a problem with configuration the Flex I/O profibus module. I have a PLC SLC 505, Profibus scaner on PLC Rack [SST-PFB-SLC] -...
52
