PV1000 self test hang at 32
davidtanwei
Jul 2007
spain
hi all,
the paneview1000 encounter an self test error 32 when it reboot.
We check that it is an something related to this powercap with crystal of part no: DS9034PCX.
We verified by changing another DS9034PCX which was removed from another panelview 600.
But no problem still hangs at 32.
Do you have any idea? anyone care to give some suggestions
regards
david
what i change is the real time clock. i take from another
panelview 600 and replace it onto my oanelview 1000. But it still doesnt work.
anyone can help?
anyone can help?
Here is a Knowledgebase article on the subject. And a link to change the battery.
http://literature.rockwellautomation.com/idc/groups/literature/documents/in/2711-in031_-mu-p.pdf
61280 - PV standard ( any 2711) - Error 32 on Self-Test Start Up
Why does PanelView 1400 self test 32 fail?
The real time clock battery test has failed. These batteries have a 7 year life span.
Replace real- time clock or send the unit for repair.
The 2711-NB2 is used with:
PV550 Keypad or Keypad and Touch Series A through Series D
The 2711-NB3 is used with:
PV550 Keypad or Keypad and Touch Series E and F
PV600 Keypad or Keypad and Touch Series A and B
PV900 All
PV1000 Keypad or Touch Series A and B
PV1400 All
The 2711-NB4 is used with:
PV300 Keypad
PV550 Keypad or Keypad and Touch Series G and later
PV550 Touch Only All
PV600 Keypad or Keypad and Touch Series C and later
PV600 Touch Only All
PV1000 Keypad and Touch Series C and later
I have a mer or apa file for Pv1000 (2711p-rdt10c) and i need convert this files for Pv5000 (2715P-T15CD-K). Are exist a conversion tool for this...
866
Hi, im looking to migrate a 2711-K10C10 to a 2711P-T12W21 Panelview Plus 7 Standard. I migrate the PV1000 application .pba file in FactoryTalk...
2,021
Hi there everyone! Long time lurker, first time poster. I am doing an SLC-5/03 to CompactLogix migration and am having an issue with a barcode...
1,062
Hi, I'm investigating the feasibility of communication between a old PV standard display and a logix L5X controller via the controller serial...
1,474
Hi all, Anyone manage to get this smorgasbord of hardware to cooperate with each other? PLC - Micrologix 1500 1764-28BXBAA CH1 config - DF1 Full...
1,506
