TCP/IP & EtherNet/IP device question
vinayakid
Dec 2007
PNQ
I am having one device by "Oriental Digital". The device is C2000 Plus S232/1 TW. This converts TCP/IP to RS232.
I want to connect this device to a Rockwell PLC/1756-ENBT module. I have to send the message to this device. But since Rockwell uses EtherNet/IP, I am not sure how to do this.I tried using "CIP Generic" Message type but no success :(
Please note that there is a managed switch between Rockwell ENBT card and C2000 converter.
If anybody came across such situation before, please let me know how to proceed.
Your "Oriental Digital" device sounds like a conventional general-purpose TCP/IP to RS-232 converter. These devices support "COM Port Redirector" software from their vendors, but seldom support industrial network protocols like EtherNet/IP or Modbus/TCP.
I do not think you will be able to get a 1756-ENBT to send data to this device.
Your alternatives are the 1756-EWEB module (more expensive and more complex) or an Ethernet -> RS232 converter that does support EtherNet/IP, like the Digi One IAP or the HMS Anybus Communicator.
What sort of serial device is connected to the Oriental Digital device ?
Hi Ken,
There is an Andon Board connected to this Device.
The PLC(L62) need to send messages to Andon board visa this converter over EtherNet.
I tried using messages but no luck so far.
I observed one point in 1756-ENBT, is that it opens a TCP connection. I could see it if I view the ENBT in internet explorer. But the messages goes into error with discription as "Connection failure"....
I looked at the site and Ken is right, it's a generic TCP RS232 converter.
forget about the C2000, what commuication option is availble for the Andon board? Do you have a link to the manual for it?
NO :( I do not have any details further. The converter is basically connected to a PCB that drives the lights/scorlling mesage on the Andon board ...
The ENBT has 64 "TCP connections". Can't that be used for sendong the message from the 1756-ENBT/A to the TCP/TP to RS232 converter?
As I understand, EtherNet/IP is the TCP encapsulation of CIP. So I am guessing that if the supplier of the "Orient Digital" converter can give the details of the message instruction (like Service code, instance, class, attribute & message structure), it can be done. Please let me know if it's correct...Help me understand more on the Ethernet/IP and TCP/IP communications!
Just to add some more info on the Oriental Digital TCP/IP to RS232 module is that I can send data to the module using Hyper terminal. It accepts the ASCII data (max 16 Characters) only.
I have a device that is currently connected to a UR 10 robot through a UR Cap and I would like to connect the device to an Allen Bradley...
412
184
Does anyone have any recommendations for Electronic Circuit Breakers with 0V Terminals built-in and Fieldbus (IO-LINK, MODBUS TCP, EtherNet/IP?)...
212
Hello, Sorry, my knowledge of communication protocol is limited, so thank you in advance for your answer. My question; I want to get 5 values...
880
Hi All, Trying to help a client who has a project that was started with Schneider STB remote I/O, but they are still waiting on the STBNIP2212...
1,957
