AC Servodriver "BAUMULLER"
shaker Hosain
Mar 2010
USA
31
Hello:
I have big problem.
I need somebody to help my.
this servo driver (BAUMULLER) has three indicators (green(ok),yallo(control disable),red(group error)).
my driver has alwasy lighted red, so I check it's datasheet to operate this driver and I followed all instructions but now way.
please if anybody can help me or guide me to another Forum to help my, please do it.
thanks
Hello Mr.kb9ttx:
this are Drivers set . they are made by “BAUMULLER”-German
Power Supply (BUG20-120-31-B-0101)
Driver (BUS 20 -60/90-31-021)
Driver (BUS 21-30/60-31-020)
Best regards
I've tested the driver(20- 30/60-31-021) recently,by following steps:
1- I connect 24VDC to ( pin 5-Control Enable).
2-connect voltage adjustable (0---10VDC)on (pin 2 (Speed control)) then the driver run.
but the Driver (BUS 20 -60/90-31-021) has still lighted red Led.
Power Supply (BUG20-120-31-B-0101)(nr.s973321176k)
Driver (BUS 20 -60/90-31-021)(nr.s9733138k)
Driver (BUS 21-30/60-31-020)(nr.s97332667k)
Best regards
I downloaded the manual from the Baumuller website for the BUS 20. Like most driver manuals, it had lots of information if you can read between the lines and try to guess.
From what I can tell, the BUS 20 has three indicator lights on the front of the driver: a green LED for "K Indicator", a yellow LED for "Controller Disable" and a red LED for "Axis Disturbance". However, the manual says that BUS 20 has seven LEDs, but their picture reference only shows three. But their circuit diagram shows 5 red LED's for the following: "Temperature of heatsink TKK too high", "Position encoder tachometer generator breakage overspeed BEDAS", "Overcurrent Izk in power unit or In motor", "Permissible time for current limit reached 'SGR' exceeded", and "Communtating signal KSIG (9 x per rev)". The last one is a flashing red LED.
Attached is a screen shot of the LED meanings from their manual.
Hopefully, something in this will lead you to your problem. Additionally, the manual references a "tester" that you could purchase to help you.
Finally, the manual can be found at http://www.baumueller.de/DownloadInternet/Kunden_Web_97.pdf
From there you will find a link to the BUS 20 manual.
Help Baumuller BKF12....6000 converter DC
Hello,
I BKF12 converter to work. Converter error is 2. (Counterclockwise rotating field on power
stage or power connection stage not
connected). Rotation of the field is ok and the thyristor voltage is.
I have a puzzle that opens the gate to plate and thyristor power module field.
If I find a wiring diagram of the plate opening thyristors or power module field.
Actually I can not get rid of error 2.
Pretty please can help me with this problem that lasts for 2 months.
thank you
hi i am looking for a copy of baumuller winbass to program bus6v i cant find anywhere not even on there site any help thanks in advance Laurence
2,669
Hello, I am looking for the error-list for bmaxx 5000 type and can't find it. I have errors 0713, 1752, 2418 showing up. Anyone knows? Thank you.
1,266
Hello, I have a baumuller bmaxx 4400 I am trying to turn a motor with using ProDrive software. Everything works fine until I try to give it a...
1,676
Anyone out there that can help me out with some Baumuller software for BUM617/618 drives? Software is PCBASS v4.01 I managed to find an old post...
2,590
I have a problem with Baumuller bum616. Which program should be used(pcbass or up/download)? Where can I download this program? There are no such...
1,532
