Micrologix 1000 Trainer Kit
goodoboy
Aug 2010
Houston
86
Hello,
Its good to back. I am planning to purchase my own PLC and kit to begin learning with hands-on to increase my skill-set. This way I can gain experience and use this to show a potential employer what I am doing at home. I been on phone interviews and its tuff to get second interview if I don't have actual real world experience. This will be a start.
1. If I purchase ($269.00) the Allen Bradley MicroLogix 1000 (model 1761-L10) - Discrete I/O kit here http://www.plctrainer.net/PLCTrainers.htm is there anyway I can add the analog (analog I/O) functionality to the PLC? I wanted to practice with analog I/O as well.
2. Can I use AB MicroLogix 1000 to write programs with different programming languages or IEC 61131-3? Or does this depends on the software RS-500.
I want to use this kit to practice some problems from the lab book on this website. This will be a good start I think. Along with relearning programming language and practicing the problems from www.thelearningpit.com. I currently have LogixPro downloaded on my laptop as a simulator.
Thank you all in advance
No, you would have to upgrade the controller.
Just assign values to the internal integer registers ( N7:??) and use them as analog inputs in your logic.
No.
Ladder logic only.
Thank you Mickey,
I have a few more questions, I'm still new and learning.
When you say "upgrade controller" does that mean upgrade to a different PLC with analog functionality, like model 1761-L20AWA-5A shown on this page?
http://www.ab.com/en/epub/catalogs/12762/2181376/2416247/1239746/2159695/tab5.html
Is this a task I can do instead of purchasing a PLC with analog I/O functionality? Or are you stating I can do this with discrete I/O only PLC to get the analog I/O functionality? Or is this something I do with a PLC that has analog I/O. I am not sure I understanding the reasoning for doing this. Can you please explain?
No.
Ladder logic only.
What AB PLC can be used for IEC 61131-3 programming languages? I can call the local AB vendor with this question as well.
Thanks for your feedback.
http://www.ab.com/en/epub/catalogs/1...9695/tab5.html
Yes.
You can do this with the discrete I/O only PLC. You just use the integer ( N7:??) data type file to represent (simulate) an analog input. You can assign analog values to these registers.
To get get something other then ladder logic your best choice would be to use the Controllogix/CompactLogix processors. They use RSLogix 5000 to program them. $$$
Thank you for reply
I will have to research/think about what you are stating. Would you recommend just spending the extra money to buy a PLC kit with analog I/O? I am trying to weigh the disadvantages and advantages. Of course price plays a roll. But if I can simulate analog values, this would be nice on the price side, not sure on the learning side.
Thanks,
The Micrologix 1100 isn't much more expensive than the 1000. Comes w/ 2 analog inputs and ethernet onboard. Plus you can add on expansion I/O if you need more I/O to play with.
Actually the 1100 is quite a bit more than the 1000 that's bundled with the trainer, but hey Thanks for the Tip on the Emulation download.
I did not know that it was available. (y)
Oh, trainer, duh I never checked the link. Hmm, wonder if you could call them and ask for a ML1100 in place of the ML1000.
I just checked my local rep for prices heh. I build my own trainers :D
Thanks for replying
I was thinking of getting this http://www.plctrainer.net/100_2333.JPG which comes with one analog I/O and lessons and free software. I will have to install this on Windows XP Professional because the RSLinx does not install on Vista Home Edition according to the supplier.
This way I have true analog I/O to practice. A bit pricey at $799.00 but the PLC by itself is 600 bucks, so I think the kit is worth the investment.
Good point. I will ask the supplier they can supply ML1100. Thanks
Building MicroLogix 1100 trainer
I am currently in Afghanistan wanting to build a MicroLogix 1100 trainer that can do all the material covered in the PLC Tutor books purchased on this site. I have a Allen Bradley MicroLogix 1100 1763-L16AWA, a 1762-CBL-PM02 serial cable and can get my hands on as much CAT 5e wire as I need. That is about it for resources here.
My research time and knowledge is limited so I am hoping some folks here may be able to assist. What else do I need to make a trainer? How many do I need? I look at websites with trainers that have switches and lamps but I do not know which ones I need or could even use. Basically, can I get a parts list and suggestions of websites to get the stuff at?
I am currently in Afghanistan .....
Are you in the military ?
I am the owner of one of the sites listed in the links www.plctrainer.net
We offer discounts to members here (plctalk.net) and discounts to military
I have a bunch of extra parts and would be glad to help you get set up... send me a email [email protected]
We use BWA's for our trainers because they are 24v but I think I still have some 110v left
Best regards
Mark
greetings Randall – and welcome to the forum ...
Mark (geniusintraining) will be able to help you out with what you'll need – and he's very easy to get along with ...
just a suggestion:
as you move forward with your project, start a new thread of your own ... you'll generate a lot more interest – and get more help from the members that way – especially if you'll mention the terms "MicroLogix 1100" and "self training" in the title ...
in case you need any "how to" help from the forum, consider posting a copy of your RSS program file ... (you'll have to zip it first – forum rule) ... the more we know about your project the more detailed the help can be ...
so it sounds like you've already got the processor and the cable ... have you also downloaded the free RSLogix500 software – and RSLinx software - and got them both running on your computer? ... have you been able to write a "bare-bones-just-getting-started" program and download it to the processor yet? ... if I understand your situation, that would be the next logical step ... basic idea: get the PLC talking/communicating with the programming computer FIRST – then go on from there ...
stay safe ...
Hi all Looking for some help please so I was connected to my MicroLogix 1000 threw rslinks had no issue. I download a program now this program...
46
13,074
So I recently purchased a micrologix 1000 1761-L16BWA from ebay to build a PLC trainer. Watching videos on the topic lead me to believe that the...
5,826
"Hello! Good day! Excuse me, I have a question regarding the 1761-NET-ENI. RSLinx has already detected it but it's not connecting to the PLC...
140
Hi all, We have a very old pit pump system running on Micrologix 1000. Now, whenever there is an alarm for high conductivity, we want that alarm...
1,258
Looking at a Micrologix 1000 1761-L32AWA, I tried to connect using the 1761-CBL-PM02 through a Serial to USB converter (This setup was used...
987
