cx file,how to open
heliosaucedo
Mar 2011
van nuys
37
i recive one file cx,this file is a program for plc, but the proble is i have syswin program and i try to open with this program and not work, how to open? i need the cx program?
is possible change cx file to syswin,
if i send this file to person has a cx program to open and change archive like pdf or another and send me back? its work?
thank you ,,
You can not go backwards - only forwards
Now I am confused - I understand you problems with english
I can assure I have problems with other languages.
But I Quote you in your last quote:-
"if some people help me plase givme a messege,
i have cx program"
Did you mean you had the copy of the code for the PLC
Are you able to talk to the PLC with your copy of SYSWIN?
I am setting up a buisnes now - I don't have CX So I can't help Yet.
However maybe someone on this site can print a PDF of your program and you can enter it to Syswin. The code should be the same.
So post a 'Zipped' copy on this thread
That is the best way.
yes man sorry i put the software wron,
i have comunication from the syswin to plc,one person send me the copy of the code for the PLC omron,
sorry for take you time,
I have a copy of CX Programmer but I currently do not have it installed on my computer. If someone else is unable to help I can install it and help you but I will wait and see if someone else who already has it installed can help first.
do you want to open a PLC file which Program by CX version from SYSwin
version?..
if that you mean ..yes u need CX version..
heliosaucedo
Can you put your PLC program in a zip file and attach it to a post in this thread? No one can do anything for you unless we have a copy of the file.
Yes it was - Youll need to read the last part of that thread to follow this one.
Thanks, jmsmoreira, I hope that helps Helio
Gets a bit confusing when theres two threads about the same thing, if it was somebody who was,nt following the previous thread they would,nt know any different and would presume this was the only thread going !!
Regards
JV
Hi guys, I am looking for some help with using GP-PRO to open a project file. Every time I try to open my project file, I receive a message...
549
Would anyone be so kind as to open a dno file and print the settings for me to enter via the keypad. We had a drive go out here and I'm trying to...
1,204
Hey everyone, Sorry if this has been asked before, I tried a search but couldn't find anything. Recently, when I try to double click a .ACD file...
3,390
I have a couple PVA files that I am unable to open. I have tried re-installing PB32. I have used versions 2.6 and 3.83. Want to see if anyone else...
1,186
How can I open a file that says "The requested resource is not recognized by the Security Authority. See your Security Administrator."
2,277
