Crimson bits in Directsoft
tommy23t
Nov 2003
New Jersey
136
Hi All,
Something obvious again escapes me. I am trying to access an individual bit in Crimson 3.0 for a G306K. For example, C135. If I enter that, it gives me an "offset badly aligned" error. If I enter C130 and try to pick the bit, no go. In the A/B, the bit array little endian comes up as a selection, but no such option here.
Thanks,
tommy23t
Thanks, but I still don't see where I can enter that. They do not give me the option to select a bit (that I can see). I enter C120, no option to offset that by 15
Ok so my first post was off of memory which is very fuzzy, my second post I went into the software and thought it didn't seem super clear to even me when I was making the screen capture...
So sent a quick message to Dan and in true Red Lion style as usual, they have already addressed it and enhanced the selection of AD tags. Download the latest build and you should see this.
I downloaded the 443 build, same thing. I guess I will call them. Your screen is the one I was expecting.;)
Thanks again
tommy23t
We may have made too many assumptions early on.
Did you create a basic tag or a flag tag? It should be a flag tag (I think this is your problem)
Did you select Treat As: Bit Array Little-Endian?
Do a screen capture or post your program.
Good morning all, I have a question that I can't seem to get a direct answer to in regards to writing HMI programs in crimson 2/3. I'm trying...
1,708
Hello, I am new to using Crimson 3 with Modbus TCP/IP Master protocol. I have a register 47101 that is packed with 16 bits for various on/off...
4,393
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
143
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
279
How do you install update on Red Lion Crimson ver 3.1. Do I just need to run the exe file on the host server?
125
