micrologix pto problem - please help
mike christen
Jun 2011
california
hello all, im really in a bind here
I'm using a micrologix 1100 to send pulses to a stepper driver for a indexing application. What I do is use the PTO jog to index until a fiber detects the cut position then send a number of pulses to index the product (desiccant) to the cutter blade using the PTO command. This works fine without a problem.
This is my problem, when the desiccant gets to the cutter it hangs sometimes on the cutter. What i need to do is run the stepper backwards just a small amount and everything would be good. So I do this in the program, change direction though a output to the stepper driver, change the PTO:0:top pulses and run the PTO. I thought this would be simple but its not working. Sometimes it works sometimes it doen't :unsure:
My questions are these:
1 - I am using the micrologix free software for programming, is there any problem i should be aware of using this rather than a full 500 software.
2 - I'm using the PTO command in different rungs, is this ok? should i only have it in one rung and have different triggers
3 - Does anyone have or be willing to write a quick and simple program to run 1 direction so many pulses than run reverse so many pulses. an output is all i change state of to change direction
If anyone could please help me I would be eternally great full
Thanks for your time.
Hi Mike ! This sounds like a neat little application.
For the MicroLogix 1100, the free version is fine. I think the only thing you lose is online cross-referencing, which isnt' a huge deal in a small controller.
I would probably use one PTO instruction, then load it with different arguments and trigger it differently.
The thing you need to investigate and concentrate on is the fact that it sometimes works, and sometimes doesn't. You need to figure out a way to diagnose this by counting pulses independent of the controller, or by performing some other diagnostic that can tell the difference between the circumstances that make it work and those that don't make it work.
If you ZIP and post your *.RSS file (or at least the part that has to do with the PTO) folks can make recommendations. RSLogix 500 is very widely used by Forum members.
Sir i have a doubt.. I have MLX 1400 (BXBA) ...I connected +24 VDC to VDC1(group2) and by default i am getting +22VDC in output 2,3,4(group2, FET outputs) even when i am not switching ON the output.... Is there any problem in PLC
Hello Aravindh
you need to apply 0vdc to the com terminal also
Good Day, I current have a setup with a Ultra3000 servo controlling a conveyor for a slicer. Recently, never before I started having a problem...
1,351
Hi, I can't seem to find a thread on this, so I'm starting one. I want to use 2 PTO outputs off a BXB 1400 Micrologix series C. BUT... I need...
1,696
Hello Everyone, I have a new project that I will be working on over the holiday break and have never done a stepper before I am using a...
2,894
I currently use a Jog Continuous at 5000hz successfully. My application requires a two speed blended jog now. I need to start the jog at a...
2,597
Hello! First time poster here. I've been in and out of PLC programming for around 10 years now. My current project has me way deeper into...
5,713
