Controllogix String Tags
rajy2r
Nov 2006
Canada
167
I have a bunch of string tags in the PLC that i need to populate. Only way i know how to do this is to type each tag in the tag editor.
Is there a more efficient way of doing this? I have a Panelview 1000, maybe i can load it from the panelview into the PLC somehow?
Would greatly appreciate the help.
Do you have a licensed copy of RSLinx that supports DDE? That is (I beleive) anything grater than lite. Then you could write a VBA macro in Excel to populate the tags. I have done this in the past.
I'll look when I have a chance. Also you could try this:
54946 - RSLogix5000 Data Preserve Download Tool
Access Level: Everyone
Date Created: 09/08/2008 02:32 PM
Last Updated: 04/22/2011 10:46 AM
This is designed to preserve data when downloading a program to a ControlLogix. It should work for you to populate your string tags.
Also I forgot to mention, You'll need to be online with the processor to use either of these methods. I thought there was a thread on this forum that someone exported tha ACD file to a L5K and added the tag values there and re-imported. You might want to search.
I consider myself an expert programmer with ControlLogix, but yesterday I started my first application with Red Lion Crimson 3 using String tags...
11,979
Hello, So i managed to read the string coming from control logix and put a string display in PanelView 800. Now I am struggling to do the other...
152
I want to create a time stamp within my PLC when an event occurs and then read and display it as a string tag in my HMIs. I figured that someone...
1,666
Hello, I am trying to import machine data from a Controllogix PLC (L71) into an excel spreadsheet for my operations people to view from their...
2,372
PLC Gurus, I need a little bit help here.. A little background, we're working on a project using PlantPAx from Rockwell.. We use some of their...
3,383
