Micrologix 1400 - error code 71h intermittent
tkeel
Aug 2005
North Carolina
I have a micrologix 1400 that will fault out on error code 71h every once in a while, I am talking months in between fault.
Now, sometimes I can clear the fault and the processor will come right back up working, no problem, and now other times, it will come back up but no I/O modules working. I shut it down again, wait a little while, start it back up, and low and behold everything works again.:unsure:
it is frustrating that it is so intermittent. Is there a way I can detect or catch what is causing the issue because it happens so infrequently? ;)
TK
I have a micrologix 1400 that will fault out on error code 79h every once in a while.
From the manual...
xx79(1) EXPANSION I/O
MODULE ERROR
An expansion I/O module generated
an error.
Non-Recoverable • Refer to the I/O Module Status (IOS) file.
• Consult the documentation for your specific
I/O module to determine possible causes of
a module error.
(1) xx indicates module number. If xx = 0, problem cannot be traced to a specific module.
Hello, I need help with PLC error code. Major error S:6 = 487h. Which is known for The expansion I/O configuration in the user program did...
2,030
Hello all, I want to get the alarms of extension modules of ml1400. There are S:6 and S:29 system datas. When a module has an error we want to...
2,670
Hello people, it's been a while... Hoping someone here with patience can help me detect a problem with this code. Its a cyclic state machine...
3,244
Hi all when i tried to upload program from micrologix 1400 series b Firmware rev 14 , at the end of upload i am getting unknown compiler error...
6,499
Hi friends,I have a machine with Micrologix 1400 PLC and My PLC goes to fault mode every 7-8 days, and error i see in PLC Fault code is MAJOR...
5,397
