Green Man
Guys
I am currently working on an application that requires me to share data on a site that currently has a number of SLC 5/04 plcs with my task being to integrate a new Compactlogix L32E. The proposed scheme is to connect via the local ethernet port on the CLX to a Control Logix Gateway, map via a routing table to a DHRIO card and thus communicate via DH+. So far I have the routing table configured and am able to drill down into each PLC from RSLinx, however no sucess has been had with setting up MSG instructions in either direction. I have a tag configured in the CLX for mapping etc.
The SLC message returns 'Target Does Not Repsond' with messaging from CLX> SLC making no sense at all. Surprised they have not added some way of setting the rout by drilling down in RSLinx.
As the site is exisitng it is likely that I will have to message from either the SLC>CLX or CLX>SLC depending on site restrictions.
Any help/ guidance would be appreciated as at the moment I am stumped and Rockwell support is pretty slow.
Green Man
Green Man
