No, if you use a pH Meter with digital On/Off output, you will pay about $500 for the meter. Buy the Siemens add-on module for your PLC, and then buy a low-cost pH electrode that can be made to work as an input to the new analog module.
Here is a Jenco 600P pH Electrode that I think would produce a miliamp signal when connected in series with a voltage source, and connected to a Siemens EM 231 Analog Input Module. (The Jenco 600p is $40.50 US).
http://www.jencostore.com/jenco-600...e-bnc-connector-3-ft-cable-max-temp-60-c.html
