I use RSLogix RSEmulate 5000 V19 and I have problem as follows,
1. When I try to download program to AB_VBP-1 , Virtual Chassis, I can not download
because There is an error message
"Error : Controller not in correct mode."
2. Later, I try to fix this problem by removing Emulator Controller ( Slot 1 )
On Chassis Monitor, But I can not remove it because
Chassis Monitor appears dialog box
"ERROR ! The Emulator module currently has faults or is in PowerUp mode.
The module can not be romoved in this state."
I check Properties of Emulator Controller ( Slot 1), I see that the Emulator Controller is in PowerUp mode
Everyone can suggest me to fix this problem
Thank,
alpine
Thank,
alpine
