I'm trying to configure an encoder with S7-300 PLC.
The module I have is SM 338 POS-INPUT, and I have an incremental encoder with resolution 4096.
I can not configure it as I do not know the no. of bits, the type of code (Gray or binary), the clock rate and the monoflop time as nothing of them is mentioned in the data sheet
the Encoder type is hohner H8A49A/AO/4096. (below the data sheet)
Technical DataConnection OptionsOperating temp:- 20 ...+ 60 degrees CCable12 pin- 4 ...+ 140 degrees FPS GNDBlack1On request:- 40 degreesPS 5 ... 24 VRed2Max frequency:150 kHzOutput AWhite3Current consumption:90 mA (max.)Output BBlue4Power supply:5 - 24VOutput OYellow5Weight: 21 oz (0.6 kg)Output A invGreen6Protection:IP 65Output B invViolet7Housing:AluminumOutput O invBrown8
Shaft:Stainless SteelBearings:2 x 6001 - (Z) (RS)Torque:0.7 oz/in (5 N-cm) Humidity:Up to 98% permissibleSpeed: 6000 RPM max.Shock:10g (6msec)Vibration:5g (500 Hz)Shaft load:Radial / Axial 10 NLine driver output max:50 mA per channelMax. ppr5000Inertia:100 gm-cm2
