mitsubishi GOT 1155
munir
Mar 2012
Karachi
21
hi guys i am currently using above mentioned HMI in a project the problem is i couldn't communicate it with pc(i used usb interface) i am using gt designer2, i managed to download the program using my desktop pc and there was no problem in that, now that the panel has been transferred to the field i needed to make changes in hmi i used my laptop to communicate with it and that's where the problem started it displays the message communication error (80022.. i haven;'t remember the full number). i will really appreciate ur advices
If I was you I would be checking the differences in your communication setup between the desktop PC and the laptop PC.
How are you trying to connect with your Laptop are you using a USB to serial (I do not know what form of communication your HMI uses, I am assuming that it is serial) if so have you set the correct comm port on your laptop for the USB to serial adapter.
thx for the reply alan
its a usb interface with usb port available on hmi all of the settings are same i think its a driver issue but even for that i have an argument i installed the software with built in drivers nd both pcs have the same software
Are we talking about comms between laptop and Got HMI or comms between Got HMI and PLC ?
As a check, go into the utility screen (how you do this depends on GOT type, check manual) then go into communication set up and check that the rs232 5 volt is active.
if this is ok you should be able to access the plc using transparent mode
Steve
hi nehpets
i am talking about comm with my laptop using usb interface, i had downloaded the program but i needed to change some stuff in it so i went there nd plugged in my usb cable from there it never communicated from my laptop interesting thing is, the current program is still working and there is no prb in comm with plc(q-06h cpu) i used 232 port for that purpose
Is there an output or something that is similar to a screen saver, but you can use in the plc to know when the user is actively using it...
505
Hello, I have a GOT 2000 that is dead and only have a GOT 1000 spare at the moment. I have converted projects up from 1000 to 2000 before, but...
793
I am trying to get a Mitsubishi GT2715 HMI to read and write from a Eurotherm 3508 controller using 4 Wire RS485 Mobus RTU communications. The...
1,311
I am trying to connect GOT-A953-tbd HMI with Nittoku NSC30. Actually, earlier GOT-A953-tbd HMI was used to communicate with Nittoku NC350 and it...
1,390
Good day all We had a GOT1020 HMI installed but has failed recently. We then Bought a GOT2103-PMBD. I need to download our old software to this...
1,417
