Difference between 1756-BA1 and 1756-BA2 Batteries
sanger
Nov 2005
Toronto
172
Is there any difference between these batteries other than the connector style?
We have a ControlLogix L61 processor with a dead 1756-BA2 battery. The plant only has spare 1756-BA1 batteries and the local Rockwell supplier does not have any stock of 1756-BA2's. Maintenance tried attaching the connector for the BA2 to the BA1 battery (red to red, black to black) but the CLX does not see it as a good battery. The battery measures 3.1V
See picture and pdf below.
It does not tell you the difference but it clearly says not to mix and match.
  • batteryusage.pdf
The 1756-BA1 battery is the battery used on the original ControlLogix L1 processors and the later L55 processors. They work fine on those processors. When the L6x processors came out, the series A used the same battery. Problem was it had really short battery life when the PLC was powered off. The series B fixed that by adding a compact flash so the battery only had to hold memory up until the processor memory was copied to flash. I wouldn't be surprised to find that the new 1756-BA2 battery has charge control and status electronics in it similar to cell phone batteries.
1756-BA1
Code:
Type: 	Lithium
Voltage: 	3.0
[B]Capacity: 	1800 mAh[/B]
Color: 	Black Heat Shrink
Size: 	0.68" dia. x 1.38" tall
1756-BA2
Code:
Type: 	Lithium
Voltage: 	3.0
[B]Capacity: 	1200 mAh[/B]
These are the details from my supplier
Good Evening , Could you folks tell me what the difference is between a 1756-L62 A and a 1756-L62 B ? I found a 1756-L62 A , but all the...
2,517
Good Evening , We are getting ready to replace some machinery and the manufacture is planning on using a 1756-EN2T . What is the difference...
7,790
Hi, What's the difference between Rockwell Controllogix 1756-ENET and 1756-ENBT card? Are they compatiable? Thanks,
8,215
Guys, I'm configuring a redundancy system (network, CPU, power supply), i used to use 1756-CNBR at the remote chassis. I'm not sure what is the...
11,422
Hello, I have a problem with AO- and AA-Tags. When I use for example the tag AO_Test with the address 200 and type the value 1,2 in, the AA-Tag...
1,434
