Communication Rslogix5000 Emulator + Simatic WinCC
SKAN_INNOVA
Mar 2012
barcelona
good afternoon
anyone knows any document or url to explain how to communicate Rslogix5000 Emulator with Simatic Wincc.
The communication between Rslogix5000 and Rslogix5000 Emulator it's ok. I Go online with the Emulator. Selecting the emulator as communication path and changing the configured CPU.
The problem is when i want to communicate with Wincc. In the Channel diagnosis of Simatic i can see that the communication fail(red cross in the wincc connection).
In Wincc the drier is OK, IP is oK and communication path= 1,0. In Rslogix i don't understand how configure the IP of the emulator. The Real PLC is not connected and i can't find this parameter in the properties of the emulator.
thanks for your help and sorry for my bad english expression.
I believe you can set the com port on the emulator, then on wincc set your com port to the same com port, or if you are on diferent ports you can patch them with a virtual port software. Hope it helps I'm not an expert on the matter but that's how I got my HMI software to run.
does Wincc got driver for AB? if so you can via virtual com port. What about opc in wincc? Does it have? I haven't eexplored wincc yet but if it does have opc, then itll be much easier.. Use your rslinx to create opc/dde topic.
Hi. Wincc Have the driver for AB, in direct connection to the PLC this driver work fine, and the communication betwee Rslogix and Wincc it's ok.
It's possible use WIncc with a OPC, but i never use it. Usually i work with S7, and simulating offline with PlCSIM.
RSLOGIX5000 and Emulator5000 are installed on 2 different PC's...I want to download logic on emulator5000.
1,874
Hello all, I'm having a problem with a Lexium Servo Drive (LXM32D18N4) from Shneider, It is controlled via a controller who gives direction...
1,397
Well guys im looking for some ideas or help with a problem that im having. I am trying to monitor the communication between rsview and logix 5000...
4,854
I configed DF1 of CompactLogix with DL3500 converter(DF1 to DH+), I don't know how to config Message at communication path box link to DF1 port...
4,957
HELLO ! I am using RsView Studio-ME with Control Logix5k processor with Ethernet driver. I am trying to import the tags from RSLogix 5K program...
5,487
