AB 1769-L18 Losing Time Setting
kamenges
Nov 2002
Green Bay, WI
4,332
Has anyone else had an issue with the realtime clock on the AB 1769-L18ER losing it's setting on a power cycle? This is the first time I've used the L18. Every time I cycle the power the time reverts to Jan 1, 1998 at 12AM. It doesn't matter how long power is down. Any power cycle will do it.
Keith
Is it loosing the program too or just the time? Is this the new ones that don't need a battery?
I haven't work with the new CompactLogix models yet. Are there time options on the DateTime page?
Yes, there are time options. They seem to be the same options as with any of the Logix family controllers. This is a standalone non-motion application so I don't have any of the time sync stuff selected.
I am running version 20 firmware, which is the first ti support the 1769-L1X controllers. So, yes, I'm dancing on the edge with this one. But it fit the app so well!!! That's what I get for looking at the new stuff, I guess.
Keith
There is a technote(479356 - 1769-L16 or 1769-L18 Processor Does Not Retain IP address on Power Cycle) about loosing the IP address during a power cycle, but nothing about the date. The TN said to remeber to save to the SD. But you don't have the SD loading on power-up, do you?
No, I don't. I haven't saved anything to the SD card yet. That reminds me that I should at some point.
I will probably send my plc program to our local distributor and have them load it on an L18 they have for training. I'll see if that one loses the clock. That will tell me if it is something in my program or something with the plc I have.
Keith
Hi everyone, Last week when I was starting up a panel with a L18 someone shut off the main breaker to my panel. After the processor powered back...
1,899
I have found that when a Momentary Push button is pressed when the power is shut off to the PanelView and CompactLogix controller. After power is...
18
4,637
I am checking to see if Metler Toledo IND 331 can communicate to the CampactLogix L18 other than ethernet. Has anyone used the USB port with a...
2,148
Good Morning , I have a MicroLogix 1500 program I would like to convert to a CompactLogix 1769-L18ER. Can I use the RS Logix 5000 Tools/...
4,028
I was reading some threads concerning instructions , WallClock , etc. What is the difference between a 1769-L32E and a 1769-L18. Are both capable...
1,860
