Assign values to HMI tags in factory talk view SE using VBA
NoLegalMoves
Jul 2012
Utah
Using VBA I am trying to assign a value to my HMI tags.
The tag name is Alarm_TM. Once this tag value is set to 1, this triggers an animation on the HMI
Here is is my code so far
Public Sub auto_open()
gTagDb.getTag("_internal\Alarm_TM").Value = 0
End Sub
Whether I set the value to 0, or 1 the animation is not changing which tells me the tag value is not assigned.
What is the proper way of doing this?
Create a tag group, add the tag(s) you need to the group. Then make the assignment, and use the "WritePendingValues(TagsInError)" method of the tag group to update them.
Tag_str = "{[" & IOTopic & "]MyDigitalTag}"
Set HMITag = MyGroup.Item(Tag_str)
HMITag.PendingWriteValue = 0
Results = MyGroup.WritePendingValues(TagsInError)
I have 32 masters in a linear topology network chain. I would prefer to use AL1xxx series from IFM. They do support device level ring if that...
1,049
On my HMI-1200, I'm trying to assign the image of a floppy disk ("save" icon) to a function key. I couldn't find one in the default drop-down...
609
Hi everybody. I got some problems about how to perform this task Now, I got an FB where I have this code snippet that looks like: L P##DBD_134...
1,143
Good Morning, I'm not sure if this is a stupid question, but I've been working with FTView ME for quite some time now and I can't solve this...
1,499
Hi I have a few Movimot motors on profinet, where i need to change the profinet name on the motor. I have been true this before, where i deleted...
2,442
