Omron PLC & Excel
fred
Nov 2002
uk
I would like to upload data memory from a CQM1H PLC into an Excel
spreadsheet.
What do I require and how ?
Any help would be welcomed.
Cheers
Fred
Fred,
If you are using CX-Programmer, there is a DDE manager under the CX-server -
Start -> Programs -> Omron -> CX-Server -> DDE manager (The path may be different depend on your installation directory).
Explore the DDE manager, you can export data to excel using that option. I have not used it for any specific applications. But tried it before and works fine.
Let me know if you need the sample I created on CPM1A.
Hi all,
I would like to do the same thing here, transfer some data from my PLC/HMI to excel sheet (Monitor the HMI data/ PLC Data) from my computer but I am using SYSMAC studio (CPU NJ501-1300) and HMI using CX-Designer NS8-TV01B-V2 system V8.6 what software I need in order to make this happen? and how?
on the other side, can SD Memory card do the same things??
Thanks a lot for your feedback.
Hi There, I have couple of Omron PLCs connected on my kepserverex and my intouch reads data from kepserverex. I have been observing that roughly...
134
I am working on a project using a NB screen and NX1P2 PLC. I am having a really hard time getting a real number to properly translate through to...
121
Our plant manger/my boss wants each line to display the takt time above the line. I am trying to research the cheapest way to do this. Our plant...
187
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
108
I have a project to control the speed of motor DC using PWM Output on PLC and when im on working i have a several trouble and of of them is the...
215
