Crimson 3.0 function questions
robinsheehy
Jun 2010
Mackay
Hello All,
I have a couple of questions about some functions available in Crimson 3.0 and was hoping that somebody maybe able to help me out.
I would like to have a string displayed on the panel that automatically shows the version of the database installed, I was thinking it would come from the cd3 file name. I have this function on the PLC I use but currently on the Redlion we have to have a fixed string that somebody needs to change each time they modify the database. I thought that the GetVersionInfo() function maybe able to help input code 1 and 2 make sense and i know they can't help me out, but I wasn't sure about input code 3. Does anybody know what information you get back from GetVersionInfo(3)?
And a quick question about SaveConfigFile(). In the reference manual is says that it will generate a CDI image file, is that still correct, or will it generate a CI3 file?
I have not used that function yet, but I would suspect that if CDI is an earlier version of the CF image stored on ComapactFlash, then you are right. I did not know that existed as a funtion. I gotta start exploring the red stuff more! I found an undocumented system variable called DispUpdates just yesterday after I had spent too much time rolling my own and fixing it.
What Build are you running? I just blew away Build 502 (emulator hangups) and am downloading 493 now (I thought it was on my thumb drive).///o_O
Happy Friday, I am trying to log scan errors related to Modbus Comms for a G306. I am able to use the system function GetDeviceStatus(x) to...
1,941
Hi, I have a Red lion HMI using crimson 3.0. I have a data entry box which has a value entered by an operator. I would like to create another data...
3,663
It seems that I recall there is a function to find the first bit set in a tag in Crimson. I am reading a fault word from a VFD and converting it...
2,445
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
149
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
298
