This thread helped me with problem I had so I will write my experience for future generations…
I had a system with one Compactlogix L35E, three AENTs, OP and SCADA, all connected via ethernet switch Westermo i-Line.
The system lived happily for a few days after set-up. But, few days later I encountered severe communication problems.
RSLogix5000 software became extremely unstable and slow to operate when online with PLC. Scrolling was laggy and general use of application became very tedious.
Few weeks after, RSLinx started to lose connection to PLC and SCADA would go blind for a few seconds every few hours…later on, every few minutes. In RSLogix5000 became impossible to go online with PLC.
Only solution I found was a restart of PLC. Do I need to say that would fix things only temporarily, for a few days/weeks?
Only thing that could be seen as suspicious on my switch diagnostics was collisions on PLC port (<0.5%) and PLC was getting a few FCS errors every now and then.
After reading this thread I examined port speed/duplex and revealed an interesting thing. Both switch and PLC ports were set to auto negotiate, but switch port ran at half speed. I had to manually set the speed on switch to 100/full and all problems went away.
I have set only a PLC port to fixed speed/duplex. AENTs were very unhappy with it and refused to play along. I was unable to get them going without errors on fixed speed/duplex.
So, thank you, forum guys.
