Factory Talk ME extremely slow to start
val_99
Mar 2005
138
I just wandering if some one bumpted into the same problem.
I'm running FT ME 6.1 under Windows 7 (i have 2 machines- 32 bit and 64 bit and both have same problem)and local FT license on C: drive.
While connected to corporate network (including internet access) some of FT applications including application manager and studio, start extremely slow. It takes up to 5-7 minutes to open an application after clickin "machine edition" on either: studio or app. manager. Also, while running it may freeze for the same time after saving, opening tag editor etc.
If I disable corporate network - problem disappears.
Third party internet connection (from wireless card) also does not create any problems.
I have contacted Rockwell tech. support but they basically don't have any idea.
Open up Factory Talk Tools > Diagnostic viewer during one of these events to see if it tells you anything.
Also, how is your license set up? Perhaps you have a license path in Factory Talk Activation Manager that is being affected by the corporate network.
We have the same problem, when talking with the AB folks they pointed us toward our IT guys and the security stuff they have running in the back ground. Will be interested if you have some feedback that helps your situation...for us... we have to live with it.
I have the same respond from Rockwell support - check with your IT dept. on network settings. It may be indeed correct, but IT guys don't have any idea what would slow down FT View. No input from tech. support on it.
151
Hi Guys, Looking for someone well versed in VBA that can either tell me a certain naming convention or point me in the right direction (I'm a...
87
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
84
Hi Friends; I have a red Explanation Mark on Factory Talk Directory in Task Bar. Before Update the windows and installation of AutoCad it works...
181
I am trying to enable an external alarm via computer speakers for Factory Talk Network Distributed Edition. I am using Alarm and Events setup. I...
187
