Tmm2112
I have just converted a PLC5 to Logix. I used an L5X export file to do a search/replace to convert the CLX array for Input and Output to the PLC5 equivalent and then a tags export file S/R to move all the tag names to those bits.
If I'm not being clear, what I mean is that in PLC5 the I/O data table is in octal, so you have I:005, I:007, I:010...etc. During the translation process, this is converted to a single dimension array that is in decimal, and the 8's and 9's are not skipped. So the PLC5 input word I:010 gets shoved into the array word I[8] just because it's the eighth word in the list of words. This also occurs at the bit level but it's not as big a problem. Maintenance personnel tend to want these addresses matching because of their familiarity with PLC5. Of course I'm talking about a system in which the 1771 I/O is remaining intact.
Does anyone know of a quicker/more efficient way of doing this than search/replace of the L5X and CSV files?
