Factory Talk View Trending / Data Logs
SamboQLD
Sep 2012
Queensland
Recently I peformed a minor update to a Panelview Plus and now all the trend data logs don't appear to be working. The trend graphs still work, but only show data from the time the graph is displayed on the screen. Historical data doesn't seem to be recording in the data log.
I did rename the application and I guess this could have had something to do with it?
Anyone know how to fix the problem?
Cheers
Exactly what was the previous version and the current version of firmware?
Create a page with a big FactoryTalk Diagnostics log object and I'll bet you see tag read failures right at the time that the Data Log starts up.
You may need to downgrade the terminal firmware. It depends on what you have and why you upgraded.
Thanks Ken, I setup a diagnostic screen as you suggested and found the problem was as simple as I had run out of storage space on the panelview to start the datalog.
143
Hi all, Attached below is an example of what is happening to our existing SCADA. It seems after patching some Rockwell Software that I thought...
337
The client has an application that when communication between the PLC and the Factory Talk VIEW supervisory fails, the object in the supervisory...
299
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
610
Hello everybody. I was wondering if there is a way in FTVIEW Studio to close ) view after x min without interaction . My issue is the following...
377
