Apologies for not providing a detailed info in my first post. Actually there are two blocks from two different programs (both programs are for the same equipment but was modified due to some issues) which I'm trying to compare. The original code is compiled in SCL for both but when comparing, I get this message as a result of comparision "Path 2 contains newer version" "Block codes are different. The absolute value of the addresses were compared". I know that the code in the concerned block for path 2 will be different as the code was modified by the OEM due to some issues after operating the equipment for a few months. When I click Go To in the comparion results window, I see this message under the comparion tab "The comparision was performed in STL because of the different programming languages!" When I open the block in path 1 (original code) which is created in SCL, it does give me a warning that the "Block and the SCL source file have different time stamps". The two codes are as follows:
Path 1 (original code)
SET
SAVE
= L 16.1
A #enaSimInBo
JCN A7d0
A #fwCnInBo
O #bwCmInBo
= #feedbackOuBo
SET
Path 2 (Modified code)
SET
SAVE
= L 16.1
A #enaSimInBo
SET
JCN A7d0
A #fwCnInBo
O #bwCmInBo
= #feedbackOuBo
SET
This is just the part of the code where the difference is. The program is for a SEW servodrive which I assume was by-passed in the modified code.
