Cup O Noodles Member C Join Date Mar 2013 Location Ohio Posts 23 Mar 22, 2013 #1 Hello all In general, how does one toggle a bit on or off in the output portion of a rung?
jstolaruk Lifetime Supporting Member J Join Date Dec 2004 Location Detroit, SE Michigan Posts 3,916 Mar 22, 2013 #2 You'll have to use the force feature if the coil is in executing logic. If your cursor is at a XIC or XIO and does not have a corresponding coil (or other), ctrl-t will toggle the bit, otherwise you'll have to use a force also.
