s7 "time of day" data type compare
gareth_mint
Dec 2010
uk
50
can someone please help me, im trying to compare two "time of day" data types but i cant seem to do it,
I have a time of day from a hmi, and i want to compare it to a set "time of day" which i have in another data block.
i just cant seem to compare if one is greater than another?
Thanks again
Gareth
Copy the blocks containing the code that you cant get to work to the library I posted, archive it and post as an attachment.
Can anyone see an issue with using a MOVE instruction to transfer a TOD into a DINT so COMPARE instructions can be used?
Using ladder.
I don't really want to disable datatype checking so I was thinking this might be a work around.
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
284
Hi guys, I have no experience when working with AllenBradley PLC, but I hope someone could clarify the result of multiplication shown in the...
2,217
Trying to get data types (AS Structures) to update after a new tag import is made from PLC. WinCC can show red if an existing element was removed...
280
Is there a way to use LREAL Data type on L71. I am getting 64 bit Double (IEEE754 Double precision 64-bit) data from a modbus device onto PLC via...
969
