Roller door... next phase
L D[AR2P#0.0]
Nov 2006
UK
6,699
Next phase is to use a global DB to specify which I/O to use for the roller door.
Start with InPEC - move InPEC boolean from the input section to the stat section. Add two more inputs called iInPECByte and iInPECBit both of type integer (this is for ease of monitoring)
Create a DB (say DB100) with an array[1..3] of structures called DoorConfig containing iInPECByte and iInPECBit
Update the calls to the doors using the byte/bit numbers from the DB
Not 100% sure on this.. this is what I have done, but do I do this for each?
Click in the comment section of the last declaration then hit return to enter another declaration.
That's the point - you are not going to pass the input as a bool anymore, you are passing the address of the input via the byte & bit number instead.
Read post #1 again.
Morning, been reading this morning and I think, I know roughly how to complete this using something along the lines of "DB3".DBX2 for example the part that is throwing me is in our array we are using two seperate locations one for the input byte and one for the bit. Im not sure how to combine them in the call? This doesnt mean Im giving up though.
Just had an idea could I use this format maybe, dont have access to simatic at work so cant check it?
P#<area><byte>.P#<bit>
.... Add two more inputs called iInPECByte and iInPECBit both of type integer...
You are going to pass two integers to the door FB, they will be combined inside the FB to form the inidrect address and access the actual input.
Arrrhhh god dam... I know where I've gone wrong, for someone reason when I modified fb2 I assumed the new parameters iInPecBtye and iInPecBit would already be there when I called the FB. Thank you for being patient with me
Here you go guys, here is my present code I have been working on.
1,360
Hello, I am currently in the final week of my internship and I have encountered issues with communication between a PowerFlex 700 variable...
69
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
69
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
61
204
