S7 Extract information from an ANY pointer in STL
Rogier89
Dec 2013
Vianen
Hi all,
I'm trying to make an universal STL function block that can be used to manage a recipe data block for several projects. The idea was to use an ANY pointer to an active recipe and to extract all information of it's DB location, the recipe size and type from that ANY pointer. With that information I want to make a new pointer to copy paste recipes from an array to the active recipe.
Does anyone know how to do this in STL?
Here is one I made earlier. It was designed to allow 20 separate production lines controlled by one PLC to share a recipe system. The recipe is a UDT so if you wish to add or subract elements, edit the UDT then recompile the other blocks.
Nick
Nick
Thank you very much, you've saved my day! :)
I've noticed a few differences between my own try and the program you posted. I made a mistake by loading the pointer directly into AR1 instead of loading it into ACCU1 and then in AR1. Also it now says "V" on the right instead of "L", do you know what those letres stand for?
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
160
Hi everyone. Quick questions. On UnityPro, I want to open and quickly read tags from a .STA files witouth opening the program. I have 30 plc...
173
Hi all, I am working with an IO link sensor (measuring current across motor)and need to read in and store the sensor values for 5 seconds, then...
1,265
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
611
Hi guys, I need a GSD file for the following sinamics drive (S120). IO Device SINAMICS S120 CU320-2 PN V4.4 PN-V2.2 with DriveES/SIMOTION...
1,521
