Tags import from Excel to Wonderware
shriram07
Dec 2013
reading
Can anyone please say if we can import tags for scada from excel to wonderware??
I have created tags of SCADA objects. I need to name each object with those name, If I can import those tags from excel to wonderware it may be useful for me as I have more than 20,000 tags...
Please help needeedo_Oo_Oo_O:unsure::unsure::unsure:
First you want to do a "DBDump" from your exsiting Wonderware Intouch app. You can find "DBDump" and "DBLoad" in the Intouch Application Manager window.
It will make a csv from the existing Intouch tags. Then you can look at the structure of that database dump to see how to set up your scada tags to do a "DBLoad" to load the database back into Intouch.
Thank you very much Bit_Bucker and NetNathan
It wass very much helpful that I solved it.
I tried to create an object and imported to csv then I tried to make changes in the csv based on the excel.
Usually I create one object on each type as few tags have alarm few do not.
But this process of converting was a time saver.
Tksssssss:geek::geek::geek:
Good day colleagues, I have a problem with a plc slc 5 since I export the tags to my factory program to load them into a panel view 1000 plus 6...
118
I am very familiar with Studio 5000 PLC programming. And I'm very familiar with C-More HMI programming. But this is my first time using a C-More...
317
I know tags can be im/exported from/to an L5K. Wondering if IO tags (Local:1:I) can be overwritten in the same way. For example, if I have an L5K...
780
Today I'm working with a MicroLogix 1400. I don't have the .rss file since we did not program the system. I was able to get the FactoryTalk file...
1,107
Odd behavior from Wonderware when I imported a couple windows. All the tags used on the windows already existed, but all of the tags came in with...
1,428
