I have been spending late nights for the past week, reading about DSOs, industrial communications, etc trying to figure out how fast of a scope I need. Every time I think I've almost got it figured out, I read something that sends me back to square one.
I am going to use the scope for checking the electrical integrity of comms busses and VFD output. I figure the comms busses will be more demanding in terms of speed, so that's what I'm focusing on. I've convinced myself: 1. that o-scope manufacturers' published bandwidth specs are almost meaningless and I should focus on single-shot sample/second and 2. that I need a scope with 50X more samples/second than the bit rate of whatever comms bus I'm going to scope. I arrived at that little thumb rule by figuring that I need 100 samples per wave period in order to get a good single-shot look for glitches and ringing, and that there's a maximum of 1 wave period per 2 bits. BUT then there's various encoding techniques that can squeeze far more than two bits into a period, meaning I could get by with a lesser scope. I just don't know which Industrial comms schemes use which encoding, and what actual baud rates (my thumb rule would be more applicable to baud rates, if they were easy to find for today's tech) I will be looking at.
The highest bit rates I expect to see in the field are 12Mbits/s (max) for Profiibus DP and 10/100Mbits/s for ethernet. What's faster than profibus but slower than ethernet? Is anything faster than ethernet? According to my thumb rule I would need a 5GSa/S scope for the ethernet, but I suspect that's wrong.
Please tell me if I'm being stupid, and while you're at it, please tell me how fast of a scope I need.
Thank you.
Thank you.
