CompactLofix To PV+ - Detect Comm Error?
skyfox
Nov 2006
CA
279
Can someone help me out on how to detect an Ethernet comm error from a PanelView + that is talking to a Compactlogix ?
I am using Factory Talk View Me 7.0.
Say for an example someone unplugging the Ethernet cable. I want to detect this comm loss and put up an alarm on the PV+ .
On the same note, how can I bring in the "Run Status" of the PLC in to PV+
Many Thanks.
There are several "pre-defined items" for each [Shortcut] in RSLinx Enterprise.
These include the [Shortcut]@IsPresent tag, and the [Shortcut]@Mode tag.
The best documentation I've found for these is in the RSLinx Enterprise online Help file.
You can use these Items directly as Alarm triggers; I do that so that I have some time-stamped records of when the PLC or network has been disconnected.
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
160
Does anyone know of a way to detect if someone is online with the controller in ControlLogix (from logic) I'm thinking that maybe there is a CIP...
420
Hi all, I am trying to find a way of detecting a motor is not isolated before attempting to run an inverter. We would normally use a 4 pole...
19
3,160
Hello everybody, I have a vendor system that has some remote monitoring (read only) and remote control (read/write) data that is available via...
2,908
1,238
