Siemens S7 ethernet protocol
fzhang
Feb 2004
Hi, everyone,
I have a Siemens S7-300 plc (cpu 314), it has a CP 343-1 module installed. Now I need to program my own windows based application (using Visual Basic or Visual C++) to exchange data with the S7 plc via TCP/IP. In order to do that, I think I need to know how the Siemens S7 ethernet protocol works, but I couldn't find the s7 protocol specification anywhere. Is there anybody who knows Siemens s7 TCP/IP protocol or has a s7 plc TCP/IP communication sample code ? Please help.
Thank you very much.
If you look in the files area there are some VB samples using native TCP. This worked well for me. In my situation I sent several data words repeatedly using the send command over a UDP connection to a C++ app and recieved command information from the app using the passive write mode.
It would also help to look through this info from Siemens.
Start with the Primer found here (NCP Primer) and then look at this (NCP Manual) that also gives sources for more information on page 8.
Enjoy
Hi, DesertDog,
Thanks for the useful information.
Regarding the VB sample code for using native TCP port, could you give me more details on how to find them?
Thanks.
C
DEAR SIR, I WOULD LIKE TO KNOW THE DIFFERENCE BETWEEN ETHERNET TCP/IP AND ETHERNET ISO (SIEMENS USES THIS PROTOCOL BETWEEN CPU 414H/417H TO WIN...
11,937
182
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
193
Can I open a Port from a Siemens PLC to an ethernet device Device will be at 192.168.0.1 and I need to open port 2112 (Upd?) Then once the...
320
382
