Upgrade Firmware in PLC5 from Series C to Series F??
In the PLC-5 family, Series letters designate different hardware.
A Series C controller can accept only higher firmware revisions (also letter or letter.number) of firmware for Series C controllers.
I do not know if the firmware for a Series C controller must be installed as a physical PROM plugs, or if some of it can be loaded through the serial port.
PLC-5 controllers could not recover as gracefully from interrupted firmware downloads as ControlLogix can, so it is very important to perform upgrade operations on a stable and reliable bench top installation.
Boy that is the TRUTH! I have bricked a couple when everything worked perfect... I do not even try anymore
Thanks for the replies.
I had a feeling that was the case...
I was hoping for a dip switch setting or hardware change but I guess not.
There are 3 PLC 5/40E Series C on the shelf here with red tags (bricks)
Rumor is someone was trying to upgrade firmware on them, must of been an expensive project??
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
189
Hello, I have a 1764 1500 LSP Series A that keeps failing with DTL_E_FAIL I/O error. Searching around it seems there's a weird issue specifically...
120
Hi Experts, I would like to make firmware upgrade from v3.0 to v4.5 (S7-1200 CPU 1215C). Can I do it from v3.0 to v4.5? Do I need to take some...
314
Hi all, I want to upgrade the firmware of some Kinetix 5500 drives. They are currently Version 2.008, and I wanted to go up to Version 7.014...
872
Does anybody know of a way I can upgrade a CompactLogix Module Firmware? We bought some "new" ones from EBay, but the firmware is 1.1
1,349
