Mitsubishi cable pinouts
jonnie75
Guest
J
Does anyone happen to know the exact cable pinout for connecting a laptop to a Mitsubishi Melsec FX-64MG plc. I was told by one of Mitsubishi's engineers that a special SC-09 cable was the only way that communications could be established at a price of $195.00. Any feed back from someone with any experience in this area would greatly be appreciated.
OK, let's see how (if?) attachments work in the new forum... utoh
Attached (maybe) is the schematic for the SC-09 cable
Now you can decide if it's worth $195.00 :D -Eric
Thanks for the schematic Eric. It looks as if it might just be easier to purchase one. It does appear as if a 4 channel 232/422 converter would do the trick. Then you could communicate with a FX but you would need the mini connnector to communicate with everything else (FX0). Don't think it is worth all of the hassle.
i can get the connector for the plc FXON
I can get the connector only for this plc FXON for about $10.00 and will orde it in a while, when i find out more info about th type of data or format this plc uses, maybe 422 or 485. I have both types of pc card over here, maybe a program coming to. Let type to get things working.
sc-09 cable
Dear Eric...
to provide us the sc-09 cable pinout was a good action, but I would like to know what integrated circuit I can use to assebly the cable. If you can help, we´ll very greatfull.
regards
thank´s
Now a will can assembly this cable!! You saved my day
Thank´s my friend!!
Less Expensive Option
I finally got an option to work, First B&B Electronics sells a REVERSE 232-422 converter (Model 422CFCR) AC adapter not included - but needed!
Use a standard RS232 cable for the PC, with an off the shelf DB-9 to DB25 adapter.
Then I had to make a DB25 to DB25 adapter cable to match the pinouts of each (sorry I can't find my notes now, but it only took me a few minutes to figure out & make the cable.)
I didn't use it but I also made the DB25 to 8 pin mini DIN for the newer PLC's.
If Eric reads this, could you possible email me that schematic directly, or tell me where i can get a copy of it, I want to be exactly sure of the pinouts, and I can't view them very well thats all. or if not, if you still have it, could you state the pinouts from top to botton for each connection for verification for me please?
I need to send a signal to our PLC (Mitsubishi Q series) which is TRUE when there's current flowing and FALSE otherwise. The thing is, the cable...
31
10,129
Hi guys I am having issue with com error popping up on a GT2104 when I press the HMI screen. I set up a full program and thought i had a problem...
1,791
Hello all! Hope everyone had a good holiday. Seems like they get shorter and shorter every year. I have a e300 HMI by beijer electronics...
2,251
I have been trying to teach myself the programming steps for the Mitsubishi PLC but i do not know if i need to make a cable or if a DF1 cable will...
1,622
