Panelview Plus 1000 and SLC 5/04
getsmart
Nov 2014
Cambridge, Ontario
I can not make to communicate a SLC 5/04 with a Panelview Plus 1000. In Local Mode everything seems OK, but in Target ... I don't realize what I am doing wrong.
Has anybody experience with that ?
Welcome to the Forum !
How are the PV+ and the SLC physically connected together ?
Local and Target are the two tabs of the RSLinx Enterprise network configuration. The Target is what is used by the PV+ or by the Test Run time on your PC.
If you are using RS232, the most common problems are the cable (PV+ has pins 2 and 3 reversed compare to your PC) and the COM port number, because the serial port on the PV+ is always COM1 but many people use USB converters that enumerate as COM3 or higher.
Thank you Ken for welcoming me!
I am able to comunicate with the panelview plus by ethernet and RS 232 with a Keyspan converter. Also I can go online with the SLC 5/04 by RS 232 but after downloading the application into the panelview plus when I conect the RS 232 cable between SLC and panelview they do not talk. ???
A typical PC serial port (including a USB/RS232 converter) and the SLC-5/04 serial port are all "Data Terminal Equipment" (DTE) type serial ports.
When you connect a DTE port to another DTE port, you need a "null modem" cable that swaps the Tx and Rx pins.
The PanelView Plus has a "Data Communication Equipment" (DCE) type port.
When you connect a DTE port to a DCE port, you need a "straight through" serial cable.
The most common way to handle this when you are using A-B processors and PanelViews is to use a "null modem adapter".
The alternative is to have two different cables: one to connect your PC to the SLC-5/04 serial port, and anther to connect the PanelView Plus to the SLC-5/04 serial port.
Getting the cable correct is step #1. Getting the COM port correct is step #2.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
181
Hi everyone, I've been tasked with creating a basic HMI for commissioning purposes for two pumps on a AB Panelview Plus 1000, 2711PRDT10C. I have...
3,018
im tring to find out if i have a bad power supply for my panelview 1000 plus. does anyone have the pinout for the 10 pin connector on the...
1,873
I need an X/Y plot to visually represent data o a roundness gage I am designing. ActiveX ME Chart Control UDT seems broke. Any advise one how to...
677
Hello Everyone, I hope we are all good today! I have a project from 2015, and the customer is locked out of the HMI. They do not know what the...
2,028
