FYI - Siemens Unmanaged Switch Bug
keithkyll
Jul 2005
Heath, TX
2,033
Have a long rung from PC to PLCs. Bought a X101-1 switch to convert Ethernet (Profinet) to fiber. (X106-1 at PLCs end).
The only configuration is via a pushbutton to step it into different fault reporting modes. This is so you can choose how the fault output operates.
Things like redundant power supply, open link, etc.
I got it into a mode where the Ethernet port was dead. No light. Fiber link and power supply lights were green. Power cycle didn't help. Manual wasn't clear.
Siemens tech support told me it can do this if it was still in setup mode. Needed to push setup button a few more times to cure it. Tech support said he saw it on an X200 product.
I promised to post this undocumented bug. I call it a bug because I think a power cycle should take it out of setup mode. Should also have a timeout.
I'm using raspberry pi 4b to poll 3 different plcs with modbus tcp and then publish the tag data using mqtt sparkplug b back to my Ignition...
3,530
This is the second time I ran into this. Really stumped me the first time and I had to flash a process back to V19. Only found this KB article...
2,059
Anyone near Chicago and going? if you go let me know how it is... I would like to go this year sometime but I need to make sure its worth the...
1,905
I know people may not get notices... Dear Rockwell Automation Software User: Rockwell Automation is releasing an update to its notice titled...
7,944
Had an issue trying to talk on a DH+ network with RSLinx Enterprise and Classic fighting over my PCMK card. The error message leads to KB article...
1,728
