ML1400 FET Outputs - Damaged, or Not?
Eric Nelson
Apr 2002
Randolph, NJ
4,346
1766-L32BXB. I screwed up and forgot to wire the COM2 terminal to DC- :sick:
I cycled one of the outputs on and off a few times, and it was working, but then the output stayed on. The other outputs in the FET group also turned on when this occurred.
I immediately realized that I forgot to wire the COM terminal. šŸ™ƒ I powered down and wired it properly. Everything is working fine now, but I'm wondering if I caused any damage.
The only things I had connected to the FET outputs were three 7W contactor coils, with suppressors (varistors), on outputs 5, 6, and 7.
I just found it odd that it actually turned on and off properly a few times without the COM2 connected :unsure:
šŸ»
-Eric
Thanks for the vote of confidence, Keith (y)
I would think the floating common should have no ill effects. I'm only concerned because it DID work a few times before staying high, which I thought was strange.
šŸ»
-Eric
The output circuitry of one channel can effectively use the common line 'felt' through another output. I've often had to trace these problems in a newly wired machine. The clue to a bad common is voltages on pins which are parts (1/3 or 1/2) of the applied voltage. There is usually a common missing somewhere.
Thanks, Bernie. That makes sense. The contactor coils connected to two other outputs would give it that path to DC common. Since I realized my mistake immediately, I didn't bother checking voltages.
šŸ»
-Eric
Hello, I am new here and have been working with PLCs for a few years now. I have been tasked with setting up a Micrologix 1400ā€¦.. to a Cmore 10...
510
Hi, We may of finally received out first v21 ML1400. IP address set, proceed to download standard file for our machines & at about the 80% mark...
1,449
I have a Allen Bradely 1500 that has a cracked board. It still works but needs replaced (battery is no longer connected). To make migration easier...
3,230
Hi, I've got a new project for a vacuum conveying system. We require to add another HMI to the existing system which will then feed 2 separate...
1,837
Hi All I have connected a Keyence SR1000 to a Compact Logix PLC and am triggering the scanner and reading barcodes over Ethernet/IP, no issues...
848
